Software updates - Suunto Nautic
Enjoy the convenience of over the air software updates via Suunto app so that your Suunto Nautic always has the latest and greatest software.
Release notes
2.55.46
Suunto Nautic - Release notes: 2.55.46
This update brings new features, improvements and bug fixes.
New Dive features:​
  • New dive mode: CCR
  • Possibility to add CCR diluent and bailout gases
  • Changed the amount of maximum allowed gases from 5 to 8
  • CCR Setpoint setting: auto and manual
  • CCR functions during dive:
    • Automatic setpoint change
    • Setpoint alarms
    • CCR switchwindow elements
  • CCR items to dive summary
  • Heart rate belt pairing
  • Allow < 18% Trimix gas mix for active agas in CCR and Multigas mode at the surface
Bug fixes:
Rain precipitation and wind sometimes 0
Fix issues if switching between languages on first set up.
The location icon occasionally disappear after panning the map
When switching between views the screen experience some lag
Wrong error message and icon if password didn’t match
The flashlight quickly discharges to low battery
Flashlight not working in factory setup
Wrong icon for pairing new device
Power consumption and charging optimization
Extend the maximum decompression time to show value instead of  >99min
The BLE chip does not always recognise clock correctly
Sometimes tank pressure alarm acknowledgment changes switch-field selection
Incomplete time points in tide chart
The curve chart of the tide chart does not have color fill
The current data line of the tide chart is too long
After changing unit settings, the widget units are not switched
Location display in tide widget is incomplete
Bug that prevented auto-start to work from the feeling view
Rounding error in GF99 calculations
When using the tide function for the first time, the synchronization time is displayed abnormally
Surface time shows always >99h if device has been powered off
Surface time field was missing from algorithm off view
The bearing pointer sometimes disappeared from compass switch window
The OTU 250 alarm was triggered at 251 and CNS 80 at 81
Wrong Traditional Chinese translation for "Device lock"
Avg & max depth didn’t show any values in switch window after surface time ends
After enabling airplane mode, the Wi-Fi switch button did not turn off.
The password lock screen will wait for 60 seconds before returning to the control panel interface.
Nautic map view shows grids when zooming too close
The error icon on the password error message screen is displayed incorrectly.
Fix how to show the name of a point of interest if too long and cannot be fully displayed
The software update displays an up arrow icon at the top
Bug that caused the button operation indicators to disappear when entering the map interface after switching the map style and directly selecting to pan the map
Nautic was missing sync state indicator
In the Chinese version, the tank pressure is displayed in English units as "psi".
Wrong pressure unit shown when mixed unit setting used
Add TTS value to delta and @ 5 values even if no deco
Diveplanner didn’t show full data if there are a lot of decostops
GF in switch window shows on gas after deco cleared
Extend the dive planner timeout
Bug that  showed GF99 1% at the surface
Algorithm deviation alarm removed from Algorithm off mode
Fix placement of update available banner
Bug that kept gas switch icon visible after gas switch
Planner last stop depth doesn't fit in spanish language
Add new gas creates extra gas switch event
Graphs should not be displayed in the log summary after a software update
2.49.32
Aggiornamento in più fasi a partire dal 13 febbraio 2026
Questo aggiornamento apporta miglioramenti e correzione di bug.
Nuove funzionalità per le immersioni:
  • Opzione per disattivare l'algoritmo di immersione durante un'immersione
Miglioramenti e correzione di bug:
  • Risoluzione di un problema relativo al salvataggio della direzione di utilizzo dopo lo spegnimento
  • Risoluzione di un problema per evitare problemi in caso di esaurimento della batteria
  • Risoluzione di un problema relativo all'icona del segno di bussola che non viene cancellata
2.49.28
Aggiornamento in più fasi a partire dal 23 gennaio 2026
Questo aggiornamento apporta nuove funzionalità, miglioramenti e correzione di bug.
Nuove funzionalità per l'immersione:
  • Opzione per definire unità separate per profondità, pressione bombola, consumo di gas, temperatura
  • Possibilità di aggiungere i valori GF99 e GF di superficie nella finestra di commutazione
  • Opzione per visualizzare un grafico a barre dei tessuti durante l'immersione
  • Opzione per resettare i tessuti
  • Widget della marea
  • Correzione dei problemi di localizzazione
  • Direzione indicata dalla bussola a volte bloccata
  • Correzioni di bug che causano il blocco della password
  • Tempo di superficie errato dopo 48 ore di inattività
  • Correzioni di indicazioni visive per le soste di decompressione
  • Elio non considerato nel grafico dei tessuti
  • Segnalazione PDI non funzionante in Mappa
  • Allarme montaggio laterale non visibile nell'app Suunto
  • Correzioni alla visualizzazione di Tank POD in modalità offline
  • Avviso velocità di risalita bloccato sulla schermata di superficie
  • Correzione del tempo di timeout in molti menu
  • Indicatori visivi dei pulsanti unificati
  • Milliradianti e gradi della bussola non centrati
  • Correzioni al pianificatore immersioni durante le immersioni con algoritmo disattivato
  • Correzioni alle icone nel widget del meteo
  • Nuovi contrassegni di certificazione
  • Icona In carica e stato di carica non visualizzati nella schermata di immersione, nel pannello di controllo e nella schermata di risparmio energetico
  • Nuovo allarme durata gas non visualizzato nell'elenco
  • Visualizzazione incoerente di NX100 e NX99
  • Il tipo di acqua non è stato modificato nel riepilogo immersione dopo essere stato aggiornato nella vista delle impostazioni
  • Correzione della modifica del gas dal menu gas
  • Il dispositivo non è passato alla modalità di risparmio energetico dalle viste del pianificatore
