Disfruta de la comodidad de las actualizaciones de software inalámbricas a través de la app Suunto, de modo que tu Suunto Ocean siempre tenga el mejor y más reciente software.
Notas de lanzamiento
2.51.28
Suunto Ocean  - Release notes: 2.51.28
Update on 12.5.2026
This update brings new features, improvements and bug fixes.
New Dive features:
  • Tide widget
  • Customization of switchwindow and arches for dive modes
  • Dynamic depth graph to dive summary
  • Option to configure a stopwatch to dive views
  • Possibility to link two tank pods to same gas If two tank pods are linked to same gas, the tank pressure field will show two tank pressures during dive
  • Option to set a pressure difference alarm when diving sidemount
  • Support for new dive watch face (available in Suunto app)
  • Water type setting for scuba diving
New Outdoor & sport features:
  • Includes features and improvements from: 2.50.26, 2.48.16, 2.44.52, 2.44.46, 2.43.1
  • Support for pairing multiple sensors of same type. Sensors will need to paired again.
  • Showing sensor information, like battery level and name
  • Downloading maps now enabled also without charger
  • ZoneSense intensity target setting in sport mode
  • Improved Climb guidance user interface and zoom enabled between waypoints
  • Passcode feature for securing the watch when off wrist
  • Support for new watch face types
  • New improved morning report
  • New notification for treadmill calibration
  • Connected sensors can be enabled/disabled per sport mode
  • Sensor services can be selected separately in sport mode
  • New default sport modes for duathlon, swimrun and aquathlon
  • New data fields: Instant, avg and lap NGP, Peak power, Peak pace & speed and ascent/descent to next waypoint
  • ZoneSense adjustable as target to follow in sport mode
  • ZoneSense zone distribution shown in log summary
  • Automatic transitions in triathlon sport mode
  • Automatic transitions in swimrun sport mode
  • Circular transition between sports in predefined multisport modes
  • New map orientation selection for north/heading
  • In-store demo mode for events and demo purposes
Improvements and bug fixes:
  • Localization fixes
  • Snorkelling max depth was missing from summary
  • Algorithm deviation icon not showing on screen after software crash Issues with surface time arch
  • Reduce the time of the no-fly icon
  • Tank pod icon showing in pre-start view even if offline
  • Issues with wifi and maps download
  • Memory optimization
  • Bearing didn’t clear after exiting Scuba dive
  • Adding e-labels for certification
  • Improvement to tank pressure arch
  • Surface time sometimes showing wrong values
  • Transition optimization in menu items
  • Wrong total dive count
  • No message after downloading maps
  • GNSS optimization happens over wireless network automatically every night
  • New winter map styles
  • A wide range of new data fields possible to add in sport mode customization
  • Improved swim style detection in pool swimming
  • Notifications show longer content than before when used with iOS
  • Zoom range indicator on map
  • Improved accuracy with updated GNSS firmware
  • Bike sensor wheel size adjustment added
  • Sleep tracking accuracy improved
  • ZoneSense zone indicator fixed
  • Some crash root causes fixed
  • Button lock problem fixed
  • Battery drain problem fixed
  • Sport mode options remembered better
  • New paired sensors automatically enabled in compatible sport modes
  • Map data field made bigger and more visible
  • Weather data also downloaded over WiFi
  • Improved pool swimming accuracy
  • Smoother transition between menus
  • Improved altimeter stability
  • Improved ascent and descent calculation accuracy
  • Several bug fixes and performance improvements
2.40.56
Actualización escalonada a partir del 16 de septiembre de 2025.
Esta actualización contiene nuevas funciones, mejoras y correcciones de errores.
Nuevas funciones de buceo:
  • Opción de restablecer los tejidos después del buceo
Nuevas funciones deportivas y outdoor:
  • Se han introducido 22 nuevos deportes. Ahora el reloj es capaz de realizar un seguimiento de más de 100 deportes: esquí de travesía, biatlón, calistenia, labores domésticas, esquí clásico, ciclocrós, e-bike, e-MTB, hockey hierba, fútbol sala, ciclismo de mano, meditación, parkour, pilates, esquí de skating, skateboarding, esquí de montaña, splitboarding, atletismo, KM vertical, deporte con silla de ruedas, yoga
  • Ahora se admiten nuevas esferas de reloj.
  • Se puede añadir una contraseña para proteger los datos sensibles.
Funciones de SuuntoPlus:
  • Nuevas esferas de reloj
  • Varias aplicaciones deportivas nuevas para los nuevos modos deportivos
  • Socios nuevos
Mejoras y correcciones de errores:
  • Las alarmas de desviación del algoritmo solo se inician al bucear.
  • Se ha corregido el error por el que las alarmas seguían activas después de finalizar el buceo.
  • Las alarmas de presión de la botella solo se restablecen cuando se excede el umbral de 1 bar.
  • Las alarmas de presión de la botella se restablecen cuando aumenta la presión. Se muestra la siguiente alarma en la ventana de cambio después de la aceptación.
  • Se actualiza el tiempo de espera para volar después de la inmersión con paradas de descompresión al valor máximo.
  • Se ha solucionado el problema por el que el icono de Tank POD aún se mostraba en la vista previa al inicio del buceo después de que Tank POD se desvinculara del gas.
  • Se puede añadir el botón de actualización a la lista del menú de Tank POD para encontrar Tank POD cercanos.
  • Se ha corregido el error por el que no se podía activar la opción de brillo para hacer snorkel o buceo.
  • Se han corregido valores PMF incoherentes.
  • Se pueden añadir opciones de mapas para buceo en apnea, snorkel y buceo de sirena.
  • Se ha mejorado aún más la precisión de la distancia de natación en piscina.
  • La calibración de la cinta para correr ya no se ve afectada por las carreras al aire libre.
  • Se han resuelto problemas con la FC diaria y el seguimiento del sueño.
  • Se ha mejorado la estabilidad de la conexión wifi.
  • Se ha reducido el tiempo de inicio automático del buceo.
  • Mejoras en la precisión del contador de pasos
  • La configuración de la esfera del reloj no se restablece cuando la esfera del reloj se actualiza en la tienda SuuntoPlus
  • Se ha corregido un error que provocaba que el seguimiento del sueño fallara en ciertos casos
  • Se han realizado mejoras generales de estabilidad y correcciones de errores.
  • Se ha mejorado la velocidad de descarga del mapa.
  • Se ha mejorado la lógica de notificaciones paso a paso.
  • Ahora la pantalla del mapa está visible durante la pausa.
2.38.42
Actualización por etapas a partir del 16 de diciembre de 2024.
  • Nueva vista de buceo con arco de brújula
  • Posibilidad de bloquear y ver el rumbo en el arco de la brújula y en el campo de ventana de cambio mientras se bucea
  • Nueva herramienta de planificación de inmersiones sin descompresión
  • Niveles de conservadurismo predefinidos para el algoritmo de buceo Bühlmann
  • mNueva opción para agregar una alarma definida por el usuario para el tiempo del NDL
  • Nueva opción para agregar una notificación de Surface para actividades de apnea
  • Las esferas de reloj se han transferido a SuuntoPlus Store.
  • Tras instalar la actualización, el reloj solo tendrá una esfera. Se pueden añadir nuevas esferas de reloj desde SuuntoPlus Store en la app Suunto.
  • Función de indicaciones de subida durante la navegación para rutas con datos de elevación
  • Posibilidad de seleccionar complicaciones con la esfera de reloj
  • Tres nuevas esferas de reloj
  • Campos de datos acumulativos como complicaciones de la esfera de reloj
  • Bloqueo de pantalla en modo reloj
  • Campo de datos en la pantalla de navegación
  • Centrado del mapa automático y personalizable
  • Ajustes específicos de visualización del modo de deporte
  • Volver una pantalla en modo de deporte manteniendo pulsado el botón central
  • Nueva interfaz de usuario de pausa y ejercicio con la posibilidad de desplazarse por las pantallas
  • Calidad del sueño en el informe sobre sueño
  • Compatibilidad con el idioma vietnamita
  • Posibilidad de seleccionar y modificar complicaciones con la esfera de reloj
  • Segundo acceso directo configurable
  • Zoom en el mapa hasta a 20 km
  • Corrección de los casos en los que el seguimiento del sueño y la FCO dejaban de funcionar
  • Corrección de un caso en el que la distancia de nado en la piscina era incorrecta en el diario de buceo
  • Corrección de un caso en el que el consumo de energía seguía siendo alto después de la navegación
  • Panel de inicio de ejercicio simplificado y más rápido
  • Capacidad mejorada de determinar el nivel de VO2máx
  • Varias mejoras cosméticas en los menús y las esferas de reloj
  • Correcciones en las traducciones a algunos idiomas
  • Ampliación de la función de emojis con colores y más personajes
  • Contador de pasos mejorado para evitar la detección de pasos errónea cuando se mueven las manos
  • Mejora del brillo de pantalla siempre activada
  • Navegación más rápida en la IU
  • Nuevo software GNSS y OHR
  • Corrección de un error que provocaba el fallo de la sincronización móvil
  • Datos de apnea que faltaban en el widget de apnea
  • Bloqueos inesperados del reloj
  • Mejoras de GPS para mediciones de distancia de snorkel
  • Hora de inicio y finalización incorrectas al utilizar el inicio automático
  • Lista de sensores que faltaba en el menú de apnea
  • Corrección de los ajustes del tiempo en superficie en caso de sincronización del reloj
  • Mejoras en la calibración de la brújula
  • Corrección de rutas de buceo que faltaban
  • Correcciones en los eventos de sincronización de la app Suunto
  • Eliminación de la parada lista si falta la última parada
  • Correcciones a los valores de techo que faltaban
  • Alarmas NDL que faltaban en la app Suunto
  • Exclusión aérea que se mostraba erróneamente después de cambiar el reloj
  • Consumo de gas que mostraba valores incorrectos
2.36.18
Actualización por etapas a partir del 5 de septiembre de 2024
Nuevas funciones:
  • Proporciona el rumbo de la brújula durante el buceo con escafandra autónoma
  • Nueva vista para el modo de buceo en apnea para incluir todas las inmersiones, profundidad, tiempo de inmersión y tiempos en superficie
  • El inicio automático para inmersiones de buceo comenzará siempre con el modo de inmersión más reciente
  • Nuevas opciones para ajustar la parada de seguridad y cómo se calcula el TTS (tiempo hasta la superficie) durante las inmersiones con paradas de descompresión
  • Valor medio de consumo de gas en el resumen de inmersión que se calculará a partir de los valores en tiempo real durante la inmersión
  • Se ha corregido un error para ajustar el brillo durante el buceo en apnea
  • Mejora de la interfaz de usuario de la Lista de gases
  • Se ha corregido un error que provocaba una lista de inmersiones vacía en el resumen del ejercicio en el modo Snorkel tras la actualización del firmware
  • Cálculos mejorados para las distancias en piscina, aguas abiertas y snorkel
  • Se ha corregido un problema por el que se mostraba mal el tiempo en superficie en el widget del historial de buceo
  • Se ha corregido un problema por el que no se mostraba el icono del cinturón de FC si la FCO estaba desactivada en la pantalla previa a la inmersión
  • Se ha corregido un error relacionado con la visualización de la recomendación del interruptor de gas durante el descenso
  • Actualización de la presión en superficie también cuando no se practican deportes acuáticos para evitar que los modos de inmersión se inicien automáticamente si baja la presión en superficie
  • Se han corregido errores relacionados con la imposibilidad de confirmar alarmas durante el buceo en apnea
  • Alarma de batería baja añadida para el buceo en apnea, buceo de sirena y snorkel
  • Modificado el comportamiento del arco para las paradas de descompresión y de seguridad
  • Aumentado el rango de duración del tiempo en superficie para mostrar los días
  • Se ha mejorado el comportamiento de las alarmas de inmersión para afrontar mejor las situaciones con múltiples alarmas de inmersión simultáneas
  • Eliminado el tiempo adicional añadido a la parada de seguridad si se realiza un ascenso rápido durante la inmersión
