Suunto Run User Guide
Intensity zones
Using intensity zones for exercising helps guide your fitness development. Each intensity zone stresses your body in different ways, leading to different effects on your physical fitness. There are five different zones, numbered 1 (lowest) to 5 (highest), defined as percentage ranges based on your maximum heart rate (max HR), pace or power.
It is important to train with intensity in mind and understand how that intensity should feel. And don't forget, regardless of your planned training, that you should always take time to warm up before an exercise.
The five different intensity zones used in Suunto Run are:
Zone 1: Easy
Exercising in zone 1 is relatively easy on your body. When it comes to fitness training, intensity this low is significant mainly in restorative training and improving your basic fitness when you are just beginning to exercise, or after a long break. Everyday exercise – walking, climbing stairs, cycling to work, etc. – is usually performed within this intensity zone.
Zone 2: Moderate
Exercising at zone 2 improves your basic fitness level effectively. Exercising at this intensity feels easy, but workouts with a long duration can have a very high training effect. The majority of cardiovascular conditioning training should be performed within this zone. Improving basic fitness builds a foundation for other exercise and prepares your system for more energetic activity. Long duration workouts at this zone consume a lot of energy, especially from your body’s stored fat.
Zone 3: Hard
Exercising at zone 3 begins to be quite energetic and feels like pretty hard going. It will improve your ability to move quickly and economically. In this zone, lactic acid begins to form in your system, but your body is still able to completely flush it out. You should train at this intensity at most a couple of times per week, as it puts your body under a lot of stress.
Zone 4: Very hard
Exercising at zone 4 will prepare your system for competition type events and high speeds. Workouts in this zone can be performed either at constant speed or as interval training (combinations of shorter training phases with intermittent breaks). High-intensity training develops your fitness level quickly and effectively, but done too often or at too high intensity may lead to overtraining, which may force you to take a long break from your training program.
Zone 5: Maximal
When your heart rate during a workout reaches zone 5, the training will feel extremely hard. Lactic acid will build up in your system much faster than it can be removed, and you will be forced to stop after a few minutes at most. Athletes include these maximum-intensity workouts in their training program in a very controlled manner, fitness enthusiasts do not require them at all.
Heart rate zones
Heart rate zones are defined as percentage ranges based on your maximum heart rate (max HR).
By default, your max HR is calculated using the standard equation: 220 - your age. If you know your exact max HR, you should adjust the default value accordingly.
Suunto Run has default and activity-specific HR zones. The default zones can be used for all activities, but for more advanced training, you can use specific HR zones for running and cycling activities.
You can select from three HR zone types:
  • Max HR zones
  • HR reserve zones
  • Lactate threshold HR zones
Your default and activity specific heart rate zones will be calculated based on the selected zone type.
Max HR zones
This is the default zone type. We recommend that you use the max HR zone setting in case you do not know your lactate threshold heart rate and your resting heart rate.
  1. Go to Activity & Training > Intensity zones > HR zones > Zone types.
  2. Select the Max HR zones option by tapping on it or pressing the crown.
  3. Scroll down and select the Default HR zones for all sports, the Running HR zones or the Cycling HR zones option.
  4. Tap the max HR (highest value, bpm) or press the crown.
    max HR
  5. Select your new max HR by swiping up or down or by turning the crown.
  6. Press the crown to confirm the selected value.
  7. On the pop-up screen, confirm if you want or don't want to update all HR zones based on max HR.
HR reserve zones
We recommend that you use the HR reserve zones setting in case you do not know your lactate threshold heart rate but you know your resting heart rate. Your HR reserve value equals to your max HR minus your resting HR value.
  2. Select the HR reserve zones option by tapping on it or pressing the crown.
  4. Select the max HR at the top of the scale by tapping it or pressing the crown.
  7. Select the resting HR at the bottom of the scale by tapping it or pressing the crown.
    HR reserve
  8. Select your new resting HR by swiping up or down or by turning the crown.
  9. Press the crown to confirm the selected value.
  10. On the pop-up screen, confirm if you want or don't want to update all HR zones based on HR reserve.
We recommend that you use the Lactate threshold HR zones setting in case you know your lactate threshold heart rate.
  2. Select the Lactate threshold HR zones option by tapping on it or pressing the crown.
  4. Tap the lactate threshold heart rate (LTHR) value or press the crown.
    LTHR
  5. Select your new lactate threshold HR by swiping up or down or by turning the crown.
  7. On the pop-up screen, confirm if you want or don't want to update all HR zones based on lactate threshold HR.
Pace zones
Pace zones work just like HR zones but the intensity of your training is based on your pace instead of your heart rate. The pace zones are shown either as metric or imperial value depending on your settings.
Suunto Run has five default pace zones that you can use or you can define your own.
Pace zones are available for running.
Set pace zones
Set your activity specific pace zones from the settings under Activity & Training > Intensity zones > Running pace zones .
  1. Swipe or turn the crown and select pace zones.
  2. Swipe up/down or turn the crown and press the crown when the pace zone you want to change is highlighted.
    pace zone
  3. Select your new pace zone by swiping up/down or by turning the crown.
  4. Press the crown to select the new pace zone value.
  5. Swipe right or press the lower button to exit the pace zones view.
Power zones
Power meter measures the amount of physical effort needed to perform a certain activity. The effort is measured in watts. The main advantage gained with a power meter is precision. The power meter reveals exactly how hard you really work and how much power you produce. It is also easy to see your progress when analyzing the watts.
Power zones can help you train with the correct power output.
Suunto Run has five default power zones that you can use or you can define your own.
Set activity specific power zones
Set your activity specific power zones from the settings under Activity & Training > Intensity zones > Running power zones or Cycling power zones.
  1. Tap the activity (running or cycling) that you want to edit or press the crown when the activity is highlighted.
  2. Swipe up or turn the crown and select power zones.
    power zone
  3. Swipe up/down or turn the crown and select the power zone you want to edit.
  4. Select your new power zone by swiping up/down or by turning the crown.
  5. Press the crown to select the new power value.
  6. Swipe right or press the lower button to exit the power zones view.
Using HR, pace or power zones when exercising
You need to have a power pod paired with your watch to be able to use power zones when exercising, see Pair devices.
When you record an exercise (see Recording an exercise), and have selected HR, pace or power as an intensity target, a zone gauge, divided into five sections, is viewed. These five sections are shown around the outer edge of the sport mode display. The gauge indicates the zone you have chosen as an intensity target by lighting up the corresponding section. The small arrow in the gauge indicates where you are within the zone range.
intensity gauge
Your watch alerts you when you hit your selected target zone. During your exercise the watch will prompt you to speed up or slow down, if your current HR, pace or power is outside the selected target zone.
target
In the exercise summary, you get a breakdown of how much time you have spent in each zone.
Innehållsförteckning
