Suunto Vertical 2 User Guide
- Navigation
Navigation
You can use your watch to navigate in various ways. You can, for example, use it to orient yourself in relation to magnetic north, navigate a route or to a point of interest (POI).
To use the navigation feature:
- Swipe up from watch face or press the lower button. - You can also access the navigation features from the compass widget.
- Select Map.
- The map display shows your current location and the surroundings.
If the compass is not calibrated, you are prompted to calibrate the compass when you enter the map.
- Press the lower button to open a list of shortcuts. The shortcuts give you quick access to navigation actions such as checking the coordinates of your current location or selecting a route to navigate.
