Suunto Run User Guide
Points of interest
A point of interest, or POI, is a special location, such as camping spot or vista along a trail, you can save and navigate to later. You can create POIs in Suunto app from a map and do not have to be at the POI location. Creating a POI in your watch is done by saving your current location.
Each POI is defined by:
  • POI name
  • POI type
  • Date and time created
  • Latitude
  • Longitude
  • Elevation
You can store up to 250 POIs in your watch.
Adding and deleting POIs
You can add a POI to your watch either with Suunto app or by saving your current location in the watch.
If you are outside with your watch and come across a spot you want to save as a POI, you can add the location directly in your watch.
To add a POI with your watch:
  1. Swipe up or turn the crown and select Navigation.
  2. From the map display, press the upper button.
  3. Select Your location by pressing the crown.
  4. Wait for the watch to activate GPS and find your location.
  5. When the watch displays your latitude and longitude, press the upper button to save your location as a POI and select the POI type.
  6. By default the POI name is the same as the POI type (with a running number after it). You can edit the name later in Suunto app.
Deleting POIs
You can remove a POI by deleting the POI from the POI list in the watch or removing it in Suunto app.
To delete a POI in your watch:
  3. Select Navigation target.
  4. Scroll to POIs and press the crown.
  5. Scroll to the POI you want to remove from the watch and press the crown.
  6. Scroll to the end of the details and select Delete.
When you delete a POI from your watch, the POI is not permanently deleted.
To permanently delete a POI, you need to delete the POI in Suunto app.
Navigating to a POI
You can navigate to any POI that is in your watch POI list.
When navigating to a POI, your watch uses full power GPS.
To navigate to a POI:
  1. Swipe up from watch face or turn the crown to go to the Navigation widget in the All Apps menu or on the list of your selected widgets and enter it.
  2. In the map display, press the upper button.
  3. Press the crown to select the Navigation target option.
  4. Scroll to POIs and press the crown to open your list of POIs.
  5. Scroll to the POI you want to navigate to and press the crown.
  6. Press the upper button or tap Navigate.
  7. If you want to stop navigating, press the upper button to open navigation options and select the End navigation option. Confirm ending the navigation by pressing the upper button.
If you only navigate to the POI without recording an exercise, nothing will be saved or logged in Suunto app.
The POI navigation has two views:
  • map view showing your current location relative to the POI and your breadcrumb trail (the track you have traveled)
    POI map view S9PP
  • POI view with direction indicator and distance to the POI
    POI detail view S9PP
Turn the crown to switch between views.
In the map view, other POIs nearby are shown in gray. Press the crown to change to the map view where you can adjust the zoom level by turning the crown.
POI types
The following POI types are available in Suunto Run:
POI BeginBegin
POI EndEnd
POI Car1Car
POI ParkingParking
POI HomeHome
POI BuildingBuilding
POI HotelHotel
POI HostelHostel
POI LodgingLodging
POI BeddingBedding
POI CampCamp
POI CampingSiteCamping site
POI CampingFireCamp fire
POI AidStationAid station
POI EmergencyEmergency
POI WaterpointWaterpoint
POI InformationInformation
POI RestaurantRestaurant
POI FoodFood
POI CafeCafe
POI CaveCave
POI MountainMountain
POI PeakPeak
POI RockRock
POI CliffCliff
POI AvalancheAvalanche
POI ValleyValley
POI HillHill
POI RoadRoad
POI TrailTrail
POI RiverRiver
POI WaterWater
POI WaterfallWaterfall
POI CoastCoast
POI LakeLake
POI KelpforestKelp forest
POI MarinereserveMarine reserve
POI CoralreefCoral reef
POI BigFishBig fish
POI MarineMammalMarine mammal
POI WreckWreck
POI FishingspotFishing spot
POI BeachBeach
POI ForestForest
POI MeadowMeadow
POI CoastCoast
POI StandStand
POI ShotShot
POI RubRub
POI ScarpeScrape
POI BigGameBig game
POI SmallgameSmall game
POI BirdBird
POI PrintsPrints
POI CrossroadsCrossroads
POI DangerDanger
POI GeocacheGeocache
POI SightSight
POI TrailcamTrailcam
Оглавление
