GET STARTED
with Suunto 5
                Welcome to the Suunto community
Thank you for choosing the new Suunto 5. Your watch will be your reliable companion for every adventure. It was built with the experience of equipping sports' enthusiast and adventurers since 1936.
Learn step-by-step how to setup your new watch and how to get started with your Suunto experience.
1. Wake up your watch
Wake up your watch by connecting it to a computer with the USB cable you will find in the box. The connector pins of the cable shall be attached to the receptors on the back of the watch.
Once your watch is awake disconnect the cable and press the middle button to get started with the setup wizard.
                2. Setup your watch
Follow the setup wizard to personalize your watch.
Based on your profile, Suunto 5 will calculate your heart rate zones and prepare your 7-day training plan. Your watch will be ready to exercise right from the start.
Let your watch know how you will wear it. This will help your Suunto 5 keep better track of your daily steps and activity.
                3. Get Suunto app
Suunto app is the mobile companion for Suunto 5 and an essential part of your new watch.
Download Suunto app on your phone. Once you have it installed, open the app and pair your watch with the app. The app will guide you through the pairing process and help you get started.
Note: The visuals may not reflect the latest version of Suunto app.
Read more about Suunto’s partners
                4. Update your watch
Your Suunto 5 will continue to grow with new features, functionalities and performance improvements. If a new update is available, we will inform you through Suunto app.
To install the updates on your watch you will need SuuntoLink - a software for your PC or Mac. Suunto app does not update your watch, but it will notify you once a new update is available.
To update, simply install SuuntoLink on your computer, connect your watch to your computer with the USB cable and SuuntoLink will prompt for an update – if one is available.
5. Go and have fun
Your watch is ready for new sports adventures. Go out and have fun!
Quick Facts
- Up to 50 meters water resistant – perfect for swimming
 - Convenient wrist-based heart rate measurement
 - Compatible with Suunto Smart Sensor heart rate belt and Bluetooth connected PODs
 - Up to 14 days of battery life in 24/7 use
 - Up to 40 h of battery life in exercise use with intelligent battery modes
Learn more about the features of your watch with how-to videos and in the Suunto 5 user guide
                Videos
Scopri come attivare Suunto 5 e completare la configurazione.
Scopri come allenarti con consigli in tempo reale e come iniziare e concludere un esercizio.
Scopri come usare le modalità batteria e prolungare la durata della stessa durante le lunghe sessioni di allenamento.
Scopri come attivare e controllare le statistiche di attività e frequenza cardiaca giornaliera nel tuo Suunto 5 e Suunto 3 Fitness.
Suunto 5 e 3 Fitness sono i tuoi compagni di allenamento perfetti che ti aiutano a migliorare la forma fisica grazie agli allenamenti con adeguamento automatico. Scopri come attivare e allenarti seguendo il programma di allenamento di 7 giorni.
Suunto 5 e 3 Fitness ti permettono di monitorare la durata e la qualità del sonno. Scopri come attivare la funzione di monitoraggio del sonno e consulta le statistiche sul sonno.
Suunto 5 e 3 Fitness ti forniscono analisi dettagliate dei tuoi livelli di energia durante il giorno. Scopri come attivare il monitoraggio di stress e recupero e come controllare i livelli delle risorse.
Scopri come associare il tuo orologio Suunto all'app Suunto per Android e come iniziare a usare l'app.
Scopri come associare il tuo orologio Suunto all'app Suunto per iOS e come iniziare a usare l'app.
Scopri come installare la versione software più aggiornata sul tuo orologio utilizzando SuuntoLink. Scarica SuuntoLink
Pulisci il tuo orologio Suunto regolarmente con acqua tiepida e detergente delicato.
Support for Suunto 5
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
