Software updates – Suunto Vertical 2
Enjoy the convenience of over the air software updates via Suunto app so that your Suunto Vertical 2 always has the latest and greatest software.
Aggiornamento software wireless
Quando è disponibile un aggiornamento e il tuo orologio è collegato all'app Suunto, l'aggiornamento software verrà scaricato automaticamente sull'orologio.
Una volta scaricato il software sull'orologio, questo si aggiornerà da solo durante la notte, purché il livello di carica della batteria sia almeno del 20%.
Se vuoi installare l'aggiornamento manualmente prima che l'installazione avvenga automaticamente durante la notte, vai su Impostazioni > Generali e seleziona Aggiornamento software.
Release notes
2.50.28
Staged update starting on January 28th 2026
This update brings bug fixes.
Bug fixes:
- Fixed a bug that disabled structured workouts in pool swimming
- Fixed a bug that disabled SuuntoPlus guides in custom made sport modes
2.50.26
Staged update starting on January 7th 2026
This update brings new features, improvements and bug fixes.
New features:
- Connected sensors can be enabled/disabled per sport mode
- Sensor services can be selected separately in sport mode
- New default sport modes for duathlon, swimrun and aquathlon
- New data fields: Instant, avg and lap NGP, Peak power, Peak pace & speed and ascent/descent to next waypoint
- Number of SuuntoPlus apps in sport mode increased from two to three
- ZoneSense adjustable as target to follow in sport mode
- ZoneSense zone distribution shown in log summary
- Automatic transitions in triathlon sport mode
- Automatic transitions in swimrun sport mode
- Circular transition between sports in predefined multisport modes
- New map orientation selection for north/heading
- In-store demo mode for events and demo purposes
Improvements:
- Significantly improved wrist heartrate accuracy
- Sport mode options remembered better
- New paired sensors automatically enabled in compatible sport modes
- Flashlight user interface improved
- Map data field made bigger and more visible
- Weather data also downloaded over WiFi
- Improved pool swimming accuracy
- Smoother transition between menus
- Improved altimeter stability
- Improved ascent and descent calculation accuracy
- Several bug fixes and performance improvements
2.48.16
Aggiornamento in più fasi a partire dal 10 novembre 2025
Questo aggiornamento apporta nuove funzionalità, miglioramenti e correzione di errori.
Nuove funzionalità:
- Tempo di contatto con il terreno e oscillazione verticale nel riepilogo del registro della corsa
- Nuova versione migliorata del report mattutino
- Nuova notifica per la calibrazione del tapis roulant
- Aggiunta la selezione di tutte le app all’elenco dei widget
Miglioramenti e correzioni di errori:
- Il problema del blocco dei pulsanti è stato risolto
- Il problema del consumo della batteria è stato risolto
