Software updates – Suunto 9 Peak Pro
Enjoy the convenience of over the air software updates via Suunto app so that your Suunto 9 Peak Pro always has the latest and greatest software.
Over the air software update
When an update is available and your watch is connected with Suunto app, the software update will be downloaded to the watch automatically.
Once the software is downloaded to your watch, the watch will update itself during the night as long as the battery level is at least 50%.
If you want to install the update manually before it happens automatically during the night, navigate to Settings > General and select Software update.
Release notes
2.50.28
Staged update starting on January 28th 2026
This update brings bug fixes.
Bug fixes:
  • Fixed a bug that disabled structured workouts in pool swimming
  • Fixed a bug that disabled SuuntoPlus guides in custom made sport modes
2.50.26
Staged update starting on January 7th 2026
This update brings new features, improvements and bug fixes.
New features:
  • Connected sensors can be enabled/disabled per sport mode
  • Sensor services can be selected separately in sport mode
  • New default sport modes for duathlon, swimrun and aquathlon
  • New data fields: Instant, avg and lap NGP, Peak power, Peak pace & speed and ascent/descent to next waypoint
  • ZoneSense adjustable as target to follow in sport mode
  • ZoneSense zone distribution shown in log summary
  • Automatic transitions in triathlon sport mode
  • Automatic transitions in swimrun sport mode
  • Circular transition between sports in predefined multisport modes
  • New map orientation selection for north/heading
  • In-store demo mode for events and demo purposes
Improvements:
  • Sport mode options remembered better
  • New paired sensors automatically enabled in compatible sport modes
  • Improved pool swimming accuracy
  • Smoother transition between menus
  • Improved altimeter stability
  • Improved ascent and descent calculation accuracy
  • Several bug fixes and performance improvements
2.48.16
Aggiornamento in più fasi a partire dal 10 novembre 2025
Questo aggiornamento apporta nuove funzionalità, miglioramenti e correzioni di errori.
Nuove funzionalità:
  • Nuova versione migliorata del report mattutino
  • Nuova notifica per la calibrazione del tapis roulant
  • Aggiunta la selezione di tutte le app all’elenco dei widget
Miglioramenti e correzioni di errori:
  • Il problema del blocco dei pulsanti è stato risolto
  • Il problema del consumo della batteria è stato risolto
2.44.52
Aggiornamento in più fasi a partire dal 25 settembre 2025
Questo aggiornamento apporta miglioramenti e correzioni di errori.
Nuove funzionalità:
  • Assistenza per associare più sensori dello stesso tipo. I sensori dovranno essere riassociati.
  • Visualizzazione delle informazioni del sensore, come il nome e il livello della batteria
  • Nuovo widget dello stato di recupero per riepilogare il tuo recupero
  • Impostazione dell’obiettivo intensità ZoneSense in modalità sport
  • Interfaccia utente delle istruzioni climb migliorate e zoom abilitato tra waypoint
  • Funzionalità passcode per proteggere l’orologio quando non lo indossi
  • Migliorato il rilevamento dello stile di nuoto in piscina
  • Le notifiche mostrano contenuti più lunghi rispetto a prima quando vengono utilizzate con iOS
  • Aggiunta la regolazione della dimensione della ruota del sensore della bicicletta
  • Migliorata la precisione del monitora sonno
  • Indicatore di zona ZoneSense fisso
  • Risolte alcune cause principali dei crash
2.43.12
Aggiornamento in più fasi a partire dal 26 giugno 2025
  • Modalità di corsa su pista all'aperto con selezione della corsia per la pista da 400 m e lunghezze di pista personalizzate da 200 m a 400 m
  • Nella personalizzazione della modalità sport è possibile aggiungere un'ampia gamma di nuovi campi dati
    • Durata ZoneSense in aerobica
    • Durata ZoneSense in anaerobica
    • Durata ZoneSense in VO2Max
    • Durata giro precedente
    • Andatura media giro precedente
    • FC media giro precedente
    • Potenza media giro precedente
    • Andatura media attività corrente (in multisport)
    • Potenza media attività corrente (in multisport)
    • Durata ascesa giro
    • Durata discesa giro
    • Durata discesa
    • Durata ascesa
    • Tempo in movimento
    • Tempo totale
    • Tempo riposo
    • Tempo pausa
    • Tempo riposo nuoto
    • Andatura media canottaggio
    • Temperatura prevista
    • Vento previsto
    • Direzione bussola
    • Zona FC attuale
    • Zona potenza attuale
    • Zona andatura attuale
    • Ore batteria
    • Percentuale batteria
    • Potenza segnale GPS
2.40.44
Aggiornamento in più fasi a partire dal 14 maggio 2025.
Miglioramenti e correzione di errori:
  • Le impostazioni del quadrante dell’orologio non vengono ripristinate quando il quadrante viene aggiornato nel SuuntoPlus Store
2.40.38
Aggiornamento in più fasi a partire dal 25 marzo 2025.
Questo aggiornamento apporta miglioramenti e correzione di errori.
  • La calibrazione del tapis roulant non viene più compromessa dalle corse outdoor
  • Precisione della distanza del nuoto in piscina migliorata ulteriormente
  • Risolti i problemi relativi alla FC giornaliera e al monitoraggio del sonno
  • Stabilità della connessione Wi-Fi migliorata
  • Assistenza per i nuovi tipi di quadrante dell'orologio
  • Velocità del download della mappa migliorata
  • Logica di notifica turn-by-turn migliorata
  • Schermata della mappa visibile durante la pausa
  • Introdotti 22 nuovi sport. Ora più di 100 sport da monitorare con l'orologio:
    sci fuoripista, biathlon, calisthenics, faccende domestiche, sci di fondo tecnica classica, ciclocross, bici elettrica, MTB elettrica, hockey su prato, futsal, paraciclismo, meditazione, parkour, pilates, sci di fondo tecnica libera, skateboard, scialpinismo, splitboard, corsa su pista, corsa vertical, sport in carrozzina, yoga
2.39.34
Aggiornamento in più fasi a partire dal 6 Gennaio 2025.
Downgrade temporaneo dal software precedente al fine di risolvere un problema critico causato dall’aggiornamento più recente. Il software è identico alla versione 2.37.48.
2.39.20
Aggiornamento in più fasi a partire dal 16 dicembre 2024
Questo aggiornamento apporta nuove funzionalità, miglioramenti e correzione di errori.
Nuove funzionalità:
  • Supporto per i nuovi quadranti natalizi nel SuuntoPlus Store
  • Aggiunto supporto per la calibrazione automatica della bussola
  • Aggiunta un’opzione di blocco pulsanti nel pannello di controllo
  • Migliorato l’aspetto visivo dei menu dell’orologio
  • Migliorata la precisione della distanza outdoor con il nuovo firmware GNSS
  • Le app per lo sport SuuntoPlus mostrano lo stato di connessione del dispositivo
  • Diverse correzioni dei bug e miglioramenti della stabilità
2.37.48
Aggiornamento graduale a partire dal 2 ottobre 2024
Questo aggiornamento porta le seguenti correzioni di bug:
  • Risolti i casi in cui il monitoraggio del sonno e l'OHR smettevano di funzionare
  • Risolto un caso in cui la distanza di nuoto in piscina era errata nel registro
  • Risolto un caso in cui il consumo di energia rimaneva elevato dopo la navigazione
2.37.34
Aggiornamento in più fasi a partire dal 4 settembre 2024
Questo aggiornamento apporta nuove funzionalità e correzione di errori.
Nuove funzionalità:
  • I quadranti dell’orologio sono stati spostati nel SuuntoPlus Store
  • Dopo l’aggiornamento, l’orologio ha un solo quadrante e i nuovi quadranti possono essere aggiunti all’orologio dal SuuntoPlus Store nell’app Suunto.
  • Pannello di avvio dell’esercizio semplificato e più veloce
  • Miglioramento della capacità di determinare il valore di VO2max
  • Miglioramenti alla funzionalità di Istruzioni climb
  • Diversi miglioramenti estetici ai menu e ai quadranti dell’orologio
  • Alcune correzioni linguistiche alle versioni tradotte
2.35.34
Aggiornamento in più fasi a partire dal 3 luglio 2024
Nuove funzionalità:
  • Funzionalità “Istruzioni climb” durante la navigazione per gli itinerari inclusi i dati di altitudine
  • Possibilità di selezionare le complicazioni dei quadranti dell’orologio
  • Tre nuovi quadranti dell’orologio
  • Campi per i dati cumulativi come complicazioni dei quadranti dell’orologio
  • Secondo accesso rapido configurabile
  • Blocco schermo in modalità orologio
  • Campo dati sullo schermo di navigazione
  • Impostazioni specifiche del display per la modalità sport
  • Ritorno alla schermata precedente mediante la pressione prolungata del pulsante centrale nella modalità sport
  • Nuova interfaccia utente per pausa ed esercizio con possibilità di navigazione tra le varie schermate
  • Supporto lingua vietnamita
  • Supporto emoji migliorato con più caratteri
  • Contapassi migliorato per evitare il rilevamento errato dei movimenti generici della mano
  • Navigazione UI più rapida
  • Nuovo software GNSS e OHR
2.33.16
Aggiornamento in più fasi a partire dal 21 maggio 2024.
  • Corretto il bug che causava la mancata sincronizzazione col dispositivo mobile
  • Risolto un problema con le guide dell’allenamento strutturato SuuntoPlus
2.33.14
Aggiornamento in più fasi a partire dal 23 aprile 2024
  • correzione dell’errore che causava lo spegnimento del dispositivo nel caricabatterie
  • Risolto un problema con la comunicazione del dispositivo SuuntoPlus
2.33.12
Aggiornamento pianificato a partire dal 25 marzo 2024.
Questo aggiornamento porta nuove funzionalità, miglioramenti e correzioni di bug.
Nuove funzionalità:
  • Tre nuovi quadranti dell'orologio
  • Promemoria di pausa e ripresa del registro all'inizio del movimento
  • Prima versione del supporto agli emoji nelle notifiche mobili
Miglioramenti e correzioni di bug:
  • Miglioramento delle prestazioni di sincronizzazione dei dati delle zone di allenamento
  • Velocità di sincronizzazione dell'app Suunto migliorata
  • Risoluzione dei problemi di stima della gara di corsa
2.30.38
Aggiornamento pianificato a partire dal 18 dicembre 2023.
Questo aggiornamento apporta miglioramenti e correzioni di bug.
Miglioramenti e bug corretti:
  • Diversi miglioramenti alla stabilità generale
  • Icona del meteo mancante nel widget risolta
  • Funzionalità del pulsante di giro risolta nelle guide SuuntoPlus
  • Problemi di rendering del riepilogo del registro in alcuni casi risolti
  • Risolti alcuni problemi di tracciamento del sonno e del contatore dei passi
2.30.32
Aggiornamento in più fasi a partire dal 30 novembre 2023.
Nuove funzionalità:
  • Nuova struttura intuitiva dell'interfaccia utente con mini widget e una personalizzazione più varia
  • Nuovi widget della Training Zone per il Punteggio dello stress da allenamento (TSS), i progressi (CTL) e il recupero (HRV e TSB).
  • Misurazione del recupero HRV durante il sonno
  • Più sveglie invece di una sola
  • Funzione “Trova il mio telefono”
  • Promemoria per alzarti
  • Nuove app sport SuuntoPlus in alcune modalità sport predefinite
  • Stime delle gare di corsa per 5 km, 10 km, mezza maratona e maratona
Miglioramenti:
  • Stabilità migliorata
  • Nuovo layout della schermata di riepilogo del registro
  • Qualità delle icone delle notifiche migliorata
  • Qualità dei comandi multimediali migliorata
  • Miglioramento dell’accuratezza GNSS con l’aggiornamento del firmware GNSS
2.27.8
Versione pubblicata in più fasi a partire dal 28 giugno 2023
Nuove funzionalità:
  • Segmenti live di Strava sull'orologio
  • Assistenza per due app sport SuuntoPlus durante la sessione
  • Le app sport SuuntoPlus vengono ricordate nel corso delle sessioni
  • Assistenza per le impostazioni delle app sport SuuntoPlus
  • Nuovo widget Condizioni meteo per le previsioni del giorno
  • Funzione torcia nel menu
  • Comandi vocali attraverso l’app Suunto
  • Nell’edizione globale sono attivate le lingue tailandese e cinese tradizionale.
Miglioramenti:
  • Miglioramenti alle impostazioni della retroilluminazione
2.22.60
Versione pubblicata gradualmente a partire dal 29 novembre 2022
Questo aggiornamento apporta miglioramenti alle prestazioni del GPS in un orologio.
Miglioramenti:
  • Tempi più brevi per trovare il segnale GPS
  • Precisione del posizionamento migliorata
  • Riacquisizione più rapida del GPS dopo una perdita di segnale
2.22.58
Pubblicazione dal 25 ottobre 2022
Questo aggiornamento apporta alcune nuove funzionalità e correzioni di alcuni bug.
Nuove funzionalità:
  • Assistenza per le connessioni dei dispositivi SuuntoPlusTM
  • Potenza della corsa misurata al polso
  • Modalità sport Snorkeling e Mermaiding
