Suunto Run User Guide
Widgets
Widgets give you useful information of your activity and training. Customize your widget list to see the information that matters most to you, whether it's your heart rate, daily step count or the current altitude, at a glance. The widgets are accessible from the watch face by swiping up and down or turning the crown.
widget list
The widgets can be turned on and off from the Control panel under Customize > Edit widgets. Select which widgets you want to use by tapping on the + and - signs next to the widget name or by pressing the crown.
You can add up to six widgets to the list.
cust widget
You can also select which widgets you want to use in your watch and in which order by turning them on and off and sorting them in Suunto app.
If an application is not added to your widget list yet, you can find it in the All Apps menu.
Indice
