Suunto Run User Guide
Multisport exercise
Your Suunto Run has predefined Triathlon sport modes that you can use to track your Triathlon exercises and races but if you need to track another sort of multisport activity, you can easily do so directly from the watch.
To use multisport exercises:
  1. Select the sport mode you want to use for the first leg of your multisport exercise.
  2. Start recording an exercise as normal.
  3. Press the crown and scroll down to enter multisport menu.
  4. Select the next sport mode you want to use and press the middle button.
  5. Adjust training mode settings
  6. Press the upper button to start the recording with the new sport mode.
    You can change sport mode as many times as you need during one single recording, including a sport mode you used previously.
Indice
