Saldi di primavera: fino al 80€ di sconto su prodotti selezionati. Scoprire
Iscriviti alla newsletter e ottieni uno sconto del 10% | Resi gratuiti
Some people choose the average – but adventurers need a tool they can trust.
With the best battery life and accuracy in the market, Suunto Vertical is the perfect companion for the highest peaks and demanding valleys.
Suunto Vertical's intuitive maps tell you all you need to know about the landscape. Contour lines, water, paths and other important landmarks are available in three different map styles.
For maximum safety, all navigation features can be used in offline mode too. Never get lost exploring!
With the altimeter, barometer and compass, you'll maintain spatial awareness with ease. In demanding surroundings, this can be a lifesaver.
Storm alarm and up to date weather forecast help you stay out of harm's way.
Suunto Vertical packs a battery life that's ahead of its competitors: 85 hours of exercise tracking on the most accurate GPS setting with the solar and titanium solar variants and 60 hours with the stainless steel variant.
In daily mode Suunto Vertical accompanies you up to 60 days – in the solar and titanium solar variants even up to one year without charging!
Suunto Vertical offre una lunga durata della batteria senza compromettere la precisione. Usa la doppia frequenza per connettersi con tutti e cinque i principali sistemi satellitari per ottenere segnali più veloci e affidabili. Inoltre, le varianti di ricarica solare forniscono un'ulteriore spinta per andare avanti ancora più a lungo.
Suunto Vertical is an excellent companion for everyday training too. From running to cycling, and swimming to cross-country-skiing, your favourite sports are sure to be found here.
Receive personalized feedback on your training load, progress and recovery, calculated based on heart rate variability (HRV). For more information, follow your efforts in Training Zone on Suunto app or coaching tools such as TrainingPeaks.
Plan, analyse and share your sports activities with Suunto App! Here, you can also connect to other services such as Strava for even more features.
Misure | 49 x 49 x 13,6 mm / 1,93 x 1,93 x 0,54 " |
Peso | 74 g / 2,61 oz |
Materiale della ghiera: | Titanio grado 5 |
Materiale del cristallo: | Cristallo zaffiro |
Materiale della cassa: | Poliammide rinforzata con fibra di vetro |
Materiale del cinturino: | Silicone |
Cosa contiene la confezione? | Suunto Vertical Titanium Solar Canyon, charging cable, printed user documentation |
Paese di produzione | CN |
Dimensioni polso: | 125-175 mm (cinturino accessorio -215 mm) |
Frequenza cardiaca al polso integrata | |
Quadranti dell'orologio personalizzabili | |
Blocco del touch screen | |
Display a sfioramento | |
Display a colori | |
Vibrazione | |
Cronometraggio automatico | |
Resistente all'acqua | 100 m |
Tipo batteria | litio-ioni ricaricabile |
Firmware aggiornabile | |
Ora, data | |
Sveglia | |
Doppio fuso orario | |
Timer conto alla rovescia | |
Cronometro | |
Lingue | EN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* |
Retroilluminazione | LED |
Retroilluminazione configurabile | luminosità automatica |
Blocco dei pulsanti | durante l'attività fisica |
Dimensione display | 1,4'' |
Tipo display | a matrice |
Risoluzione del display | 280 x 280 |
Indicatore carica batteria | percentuale / icona |
Unità di misura metrica/anglosassone | |
Saturazione ossigeno | |
Aggiornamenti automatici wireless del firmware | |
Larghezza del cinturino: | 22 mm |
Archiviazione mappe offline per attività all'aperto | 32GB |
Display sempre acceso |
Compatibilità con smartphone | Modelli più comuni supportati |
Connettività (tra dispositivi) | Bluetooth |
Le notifiche del telefono sull'orologio | |
Comandi multimediali sull'orologio | |
Invio di risposte precompilate dall'orologio ai messaggi in arrivo | Solamente Android |
Compatibile con le comunità sportive online | |
Aggiornamenti del software dell'orologio dal cloud | |
Suunto app compatibile | |
Aggiornamenti software over-the-air automatici |
Bussola digitale | |
Compensazione inclinazione | |
Scala direzione | gradi / mil |
Taratura | indicatore Nord |
Precisione della bussola | 5° |
Risoluzione bussola | 1° |
Correzione della declinazione |
Temperatura operativa | da -20 °C a +55 °C/da -5 °F a +130 °F |
Temperatura di conservazione | da -20 °C a +55 °C/da -5 °F a +130 °F |
Temperatura batteria in carica: | da 0° C a +45° C /da +32° F a +113° F |
Promemoria carica intelligenti | |
Uso quotidiano: modalità smartwatch | fino a 30 giorni (60 giorni con Solar) |
Uso quotidiano: solo modalità standby | fino a 60 giorni (1 anno con Solar) |
Allenamento: modalità GNSS tutti i sistemi + multi-banda | fino a 65 h (90 h con Solar) |
Allenamento: modalità GNSS tutti i sistemi + banda singola | fino a 90 h (140 h con Solar) |
Allenamento: promesse di batteria per tutte le modalità | 65h / 90h / 140h / 500h (Solar 90h/ 140h/ 280h/ 30g) |
Allenamento: modalità GNSS a risparmio energetico | fino a 500 h |
Controlla la musica con l'orologio |
Profondimetro per lo snorkeling | 10 m |
Sistemi satellitari | GPS, GLONASS, GALILEO, QZSS, BEIDOU |
Sistemi satellitari simultanei | 4 |
Satelliti max. collegati | 32 |
Frequenza registrazione GPS | Migliore, Buona, OK, Bassa |
Modalità batteria intelligenti | Performance, Endurance, Ultra, Tour, Personalizzata |
Tappe intermedie (waypoint) e navigazione grafica itinerari | |
Livelli di zoom nella navigazione | |
Zoom automatico basato sulla conformazione dell'itinerario | |
Funzione di tracciamento automatico del percorso (breadcrumb) in tempo reale | |
Mappe terreni outdoor e satellitari | |
Mappe di calore globali per 20 sport | |
Pianificazione itinerari con mappe di calore | |
Libreria personale itinerari nel Web sincronizzata con l'orologio | |
Segui percorso | |
Navigazione punti di interesse (PDI) | |
ETA (ora di arrivo prevista) | |
Analisi percorsi GPS | |
Registrazione, visualizzazione e condivisione percorsi | |
Mappe offline sull’orologio | |
GNSS frequency support | L1 + L5 |
Pianificazione itinerari con profilo altitudine | |
Mappe outdoor da satellite, terreno e topografia sul Web tramite Mapbox, Google Maps e Android | |
Navigazione rotta | |
ETA (estimated time of arrival, ora di arrivo prevista), distanza residua |
Altitudine barometrica | |
Altitudine GPS | |
Combinazione altitudine GPS e barometrica (FusedAlti™) | |
Altitudine in modalità giornaliera | |
Acclimatamento all'altitudine con la funzione di saturazione ossigeno | |
Ascesa/discesa totale | |
Velocità verticale | |
Profilo alti/baro automatico | |
Frequenza di registrazione | 1 s |
Risoluzione | 1 m |
Rilevazione altitudine | -500 - 9999 m |
Ora di alba e tramonto | |
Allarme temporale/tempesta | |
Pressione a livello del mare | |
Temperatura | |
Intervallo visualizzazione temperatura | da -20° C a +55° C/da -5° F a +130° F |
Risoluzione temperatura | 1° C / 1,5° F |
Risoluzione pressione | 1 hPa |
Grafico di altitudine visualizzato nel riepilogo dell'attività fisica |
Allenamento guidato in tempo reale basato su intensità e durata |
Indicazioni sugli intervalli durante l'allenamento | |
Configurazione intervalli | |
Intervalli strutturati |
Frequenza cardiaca misurata al polso | |
Compatibilità fasce cardio | fasce Bluetooth Smart |
Intervallo RR | con fascia cardio Suunto Smart e Suunto Smart Sensor |
Frequenza cardiaca in battiti al minuto | |
Registra la frequenza cardiaca durante il nuoto | |
Grafico frequenza cardiaca in tempo reale | |
Frequenza cardiaca media in tempo reale | |
Calorie | |
PTE (Picco effetto allenamento) | |
Tempo di recupero | |
Zone di frequenza cardiaca personali | |
Livello di fitness (VO2 max) |
Registro con dettagli dell'allenamento | |
Riepilogo dell'allenamento con dettagli sui giri | |
Carico di lavoro con totali suddivisi per sport | |
Registro degli allenamenti per panoramiche a lungo termine | |
Riepilogo registri sull'orologio con dettagli sui giri |
Tempo di recupero in base all'allenamento | |
Stato d'animo salvato sull'orologio dopo l'allenamento |
Valutazione e commenti sull'allenamento | |
Condivisione dell'allenamento sui social media | |
Segui gli altri utenti e ottieni feedback tramite il flusso di attività |
Distanza e velocità basate sulla cadenza | |
Velocità e distanza calcolata tramite GPS | |
Cronografo | |
Supporto per Foot POD | Bluetooth Smart |
Autolap | |
Giri - manuale | |
Analisi dell'andatura, grafici della velocità e percorsi sulla mappa |
Contapassi | |
Calorie bruciate | |
Obiettivi delle attività | |
Cronologia attività | |
Conteggio delle calorie bruciate e frequenza cardiaca durante le attività quotidiane | |
Monitoraggio quotidiano della frequenza cardiaca minima |
Durata del sonno | |
Ora in cui ci si va a letto | |
Qualità del sonno | |
Orario sveglia | |
Frequenza cardiaca media e minima durante il sonno | |
Deep sleep | |
HRV da sonno | |
Sonno leggero |
Livello di risorse giornaliero | |
Stato dello stress e del recupero | |
Misurazione HRV |
Riepilogo attività fisica multisport sull'orologio | |
Cambio modalità per lo sport durante attività fisica | |
Modalità multisport preconfigurate | |
Analisi a posteriori di attività multisport per sport |
Andatura corsa | |
Suunto FusedSpeed™ | |
Segui percorso | |
Potenza della corsa | dal polso o con sensore Stryd |
SuuntoPlus™ Ghost runner | |
Calibrazione Foot POD | automatico |
Tabella giri nell'orologio e nell'app Suunto | |
Andatura giro in tempo reale, max, media | |
Indicazioni sugli intervalli con andatura corsa/frequenza cardiaca/distanza |
Velocità bicicletta | |
Velocità media in tempo reale | |
Bike POD con supporto velocità/cadenza | Bluetooth Smart |
Supporto misuratore Bike Power | Bluetooth Smart |
Bike Power (potenza pedalata) (W), valore medio e max (con sensore potenza) | Bluetooth Smart |
Giro e potenza max giro (con sensore potenza) | |
Tabella dei giri in tempo reale con frequenza cardiaca, potenza media e velocità media | |
Indicazioni sugli intervalli con potenza/velocità/frequenza cardiaca |
Andatura e distanza nuoto in vasca | |
Distanza nuoto in acque libere | |
Tempo per vasca, giro (frazione), totale | |
Frequenza, numero e tipo bracciate | |
Efficienza nuotata (SWOLF) | |
Intervalli automatici | |
Tabella giri intervalli |
Visualizzazioni e modalità per lo sport personalizzabili | |
Display grafici nelle modalità sport | |
Modalità sport preinstallate nell'orologio | > 95 |
SuuntoPlus™ |
Paese o area geografica:
United States
