Disfruta de la comodidad de la actualización de software inalámbrica a través de la app Suunto, de modo que tu reloj siempre tenga el mejor y más reciente software.
Actualización inalámbrica de software
Cuando haya una actualización disponible y tu reloj esté conectado con la app Suunto, la actualización del software se descargará al reloj automáticamente.
Una vez se haya descargado el software al reloj, este se actualizará durante la noche, siempre que la batería tenga un nivel mínimo del 50 %.
Si quieres instalar manualmente la actualización antes de que se lleve a cabo automáticamente durante la noche, desplázate a Ajustes > General y selecciona Actualización de software.
Notas de lanzamiento
Over the past four years, Suunto 9 Peak Pro has received a wide range of new features, enhancements, and software updates.
Today, Suunto 9 Peak Pro remains a feature-rich, proven, andtrusted companion for athletes and adventurers around the world.
Going forward, no additional feature updates or software updates are planned for Suunto 9 Peak Pro. This ensures the device continues providing the stable, reliable performance you depend on.
You don't need to do anything. Your Suunto 9 Peak Pro will continue to perform exactly as it does today, ready for the adventures ahead.
Your experience continues to grow through the Suunto app,where you can download new watch faces and sport apps for your Suunto 9 Peak Pro.
2.50.28
Staged update starting on January 28th 2026
This update brings bug fixes.
Bug fixes:
  • Fixed a bug that disabled structured workouts in pool swimming
  • Fixed a bug that disabled SuuntoPlus guides in custom made sport modes
2.50.26
Staged update starting on January 7th 2026
This update brings new features, improvements and bug fixes.
New features:
  • Connected sensors can be enabled/disabled per sport mode
  • Sensor services can be selected separately in sport mode
  • New default sport modes for duathlon, swimrun and aquathlon
  • New data fields: Instant, avg and lap NGP, Peak power, Peak pace & speed and ascent/descent to next waypoint
  • ZoneSense adjustable as target to follow in sport mode
  • ZoneSense zone distribution shown in log summary
  • Automatic transitions in triathlon sport mode
  • Automatic transitions in swimrun sport mode
  • Circular transition between sports in predefined multisport modes
  • New map orientation selection for north/heading
  • In-store demo mode for events and demo purposes
Improvements:
  • Sport mode options remembered better
  • New paired sensors automatically enabled in compatible sport modes
  • Improved pool swimming accuracy
  • Smoother transition between menus
  • Improved altimeter stability
  • Improved ascent and descent calculation accuracy
  • Several bug fixes and performance improvements
2.48.16
Actualización por etapas a partir del 10 de noviembre de 2025
Esta actualización contiene nuevas funciones, mejoras y correcciones de errores.
Nuevas funciones:
  • Informe matutino nuevo y mejorado
  • Nueva notificación para la calibración de la cinta para correr
  • Todas las aplicaciones seleccionadas se han añadido a la lista de widgets
Mejoras y correcciones de errores:
  • Se ha corregido el problema del bloqueo de botones
  • Se ha corregido el problema de la descarga excesiva de la batería
2.44.52
Actualización por etapas a partir del 25 de Septiembre de 2025
Esta actualización contiene mejoras y correcciones de errores.
Nuevas funciones:
  • Compatibilidad con el acoplamiento de varios sensores del mismo tipo. Los sensores deberán acoplarse de nuevo.
  • Ahora se muestra información del sensor, como el nivel de batería y el nombre.
  • Nuevo widget de estado de recuperación para resumir tu recuperación.
  • Ajuste de objetivos de intensidad ZoneSense en modo de deporte.
  • Interfaz de usuario de indicaciones de subida mejorada y zoom habilitado entre puntos de referencia.
  • Función de contraseña para proteger el reloj al quitárselo de la muñeca.
  • Se ha mejorado la detección del estilo de natación en piscina.
  • Las notificaciones muestran contenido más largo que antes en iOS.
  • Se ha agregado el ajuste del tamaño de la rueda del sensor de bicicleta.
  • Se ha mejorado la precisión del seguimiento del sueño.
  • Se ha corregido el indicador de zona ZoneSense.
  • Se han corregido algunas causas fundamentales de fallos.
2.43.12
Actualización por etapas a partir del 26 de junio de 2025
  • Modo de carrera en pista al aire libre con selección de carril para pista de 400 m y longitudes de pista personalizadas de 200 m a 400 m
  • Una amplia gama de nuevos campos de datos que se pueden agregar en la personalización del modo de deporte
    • Duración de ZoneSense en ejercicio aeróbico
    • Duración de ZoneSense en ejercicio anaeróbico
    • Duración de ZoneSense en VO2máx.
    • Duración de vuelta anterior
    • Ritmo medio de vuelta anterior
    • FC medio de vuelta anterior
    • Potencia media de vuelta anterior
    • Ritmo medio de actividad actual (multideporte)
    • Potencia media de actividad actual (multideporte)
    • Duración de vuelta de ascenso
    • Duración de vuelta de descenso
    • Duración de descenso
    • Duración de ascenso
    • Tiempo en movimiento
    • Tiempo total
    • Tiempo de descanso
    • Tiempo en pausa
    • Tiempo de descanso de natación
    • Ritmo medio de remo
    • Temperatura pronosticada
    • Viento pronosticado
    • Rumbo de la brújula
    • Zona de FC actual
    • Zona de potencia actual
    • Zona de ritmo actual
    • Horas de batería
    • Porcentaje de batería
    • Potencia de señal GPS
2.40.44
Actualización por etapas a partir del 14 de mayo de 2025.
  • La configuración de la esfera del reloj no se restablece cuando la esfera del reloj se actualiza en la tienda SuuntoPlus
2.40.38
Actualización por etapas a partir del 25 de marzo de 2025
  • La calibración de la cinta para correr ya no se ve afectada por las carreras al aire libre.
  • Se ha mejorado aún más la precisión de la distancia de natación en piscina.
  • Se han resuelto problemas con la FC diaria y el seguimiento del sueño.
  • Se ha mejorado la estabilidad de la conexión wifi.
  • Ahora se admiten nuevas esferas de reloj.
  • Se ha mejorado la velocidad de descarga del mapa.
  • Se ha mejorado la lógica de notificaciones paso a paso.
  • Ahora la pantalla del mapa está visible durante la pausa.
  • Se han introducido 22 nuevos deportes. Ahora el reloj es capaz de realizar un seguimiento de más de 100 deportes:
    esquí de travesía, biatlón, calistenia, labores domésticas, esquí clásico, ciclocrós, e-bike, e-MTB, hockey hierba, fútbol sala, ciclismo de mano, meditación, parkour, pilates, esquí de skating, skateboarding, esquí de montaña, splitboarding, atletismo, KM vertical, deporte con silla de ruedas, yoga
2.39.34
Actualización por etapas a partir del 6 de enero de 2025
Vuelta a una versión anterior del software para solucionar un problema crítico causado por la última actualización. Este software es prácticamente la misma versión que 2.37.48.
2.39.20
Actualización por etapas a partir del 16 de diciembre de 2024.
Nuevas funciones:
  • Compatibilidad con las nuevas esferas de reloj navideñas disponibles en la SuuntoPlus Store
  • Compatibilidad con la calibración automática de la brújula.
  • Nueva opción de bloqueo de botones en el panel de control.
  • Mejora del aspecto visual de los menús del reloj.
  • Precisión de distancia en exteriores mejorada con el nuevo firmware GNSS.
  • Se han corregido problemas con la FC diaria y el seguimiento del sueño.
  • Las aplicaciones deportivas SuuntoPlus muestran el estado de conexión del dispositivo.
  • Varias correcciones de errores y mejoras de estabilidad.
2.37.48
Actualización escalonada a partir del 2 de octubre de 2024
Esta actualización trae las siguientes correcciones de errores:
  • Se corrigieron casos donde el seguimiento del sueño y el OHR dejaron de funcionar
  • Se corrigió un caso donde la distancia de natación en piscina era incorrecta en el registro
  • Se corrigió un caso donde el consumo de energía permanecía alto después de la navegación
2.37.34
Actualización por etapas a partir del 4 de septiembre de 2024
Nuevas funciones:
  • Las esferas de reloj se han transferido a SuuntoPlus Store.
  • Tras instalar la actualización, el reloj solo tendrá una esfera. Se pueden añadir nuevas esferas de reloj desde SuuntoPlus Store en la app Suunto.
  • Panel de inicio de ejercicio simplificado y más rápido
  • Capacidad mejorada de determinar el nivel de VO2máx.
  • Mejoras a la funcionalidad de indicaciones de subida
  • Varias mejoras cosméticas en los menús y las esferas de reloj
  • Correcciones en las traducciones a algunos idiomas
2.35.34
Actualización por etapas a partir del 3 de julio de 2024
Nuevas funciones:
  • Función de indicaciones de subida durante la navegación para rutas con datos de elevación
  • Posibilidad de seleccionar complicaciones con la esfera de reloj
  • Tres nuevas esferas de reloj
  • Campos de datos acumulativos como complicaciones de la esfera de reloj
  • Segundo acceso directo configurable
  • Bloqueo de pantalla en modo reloj
  • Campo de datos en la pantalla de navegación
  • Ajustes específicos de visualización del modo de deporte
  • Volver una pantalla en modo de deporte manteniendo pulsado el botón central
  • Nueva interfaz de usuario de pausa y ejercicio con la posibilidad de desplazarse por las pantallas
  • Compatibilidad con el idioma vietnamita
  • Ampliación de la función de emojis con más personajes
  • Contador de pasos mejorado para evitar la detección de pasos errónea cuando se mueven las manos
  • Navegación más rápida en la IU
  • Nuevo software GNSS y OHR
2.33.16
Actualización por etapas a partir del 21 de mayo de 2024
  • Corrección de un error que provocaba el fallo de la sincronización móvil
  • Solución de un problema con las guías de entrenamientos estructurados de SuuntoPlus™
2.33.14
Actualización por etapas a partir del 23 de abril de 2024
  • Corrección de un error que provocaba que el dispositivo se quedara en blanco en el cargador
  • Corrección de un problema con la comunicación con el dispositivo SuuntoPlus™
2.33.12
Actualización escalonada a partir del 25 de marzo de 2024.
Esta actualización trae nuevas funciones, mejoras y correcciones de errores.
Nuevas funciones:
  • Recordatorio de pausa y reanudación del registro al comenzar a moverse
  • Primera versión de soporte de emojis en notificaciones móviles
  • Mejora del rendimiento de sincronización de datos de la zona de entrenamiento
  • Mejora de la velocidad de sincronización de la aplicación Suunto
  • Problemas de estimación de carrera resueltos
2.30.38
Actualización programada a partir del 18 de diciembre de 2023.
Esta actualización trae mejoras y correcciones de errores.
Mejoras y errores corregidos:
  • Varias mejoras en la estabilidad general
  • Icono de clima faltante en el widget corregido
  • Funcionalidad de botón de vuelta corregida en las guías de SuuntoPlus
  • Problemas de renderización de resumen de registro en algunos casos corregidos
  • Problemas con el seguimiento del sueño y el contador de pasos corregidos
2.30.32
Actualización por etapas a partir del 30 de noviembre de 2023
Nuevas funciones:
  • Nueva estructura intuitiva de la IU con miniwidgets y una personalización mejorada
  • Nuevos widgets de Training Zone para el Entrenamiento (TSS), Progreso (CTL) y Recuperación (VFC y TSB).
  • Medición de la recuperación con VFC durante el sueño
  • Múltiples alarmas en lugar de una
  • Función Encontrar mi teléfono
  • Recordatorio de ponerte de pie
  • Nuevas apps deportivas SuuntoPlus en varios modos de deporte predeterminados
  • Estimaciones de carreras de 5K, 10K, media maratón y maratón
Mejoras:
  • Estabilidad mejorada
  • Nuevo diseño de la pantalla de resumen del registro
  • Iconos de notificación mejorados
  • Controles multimedia mejorados
  • Precisión de GNSS mejorada con firmware de GNSS actualizado
2.27.8
Lanzamiento por etapas a partir del 28 de junio de 2023
Nuevas funciones:
  • Segmentos de Strava Live en el reloj
  • Compatibilidad con dos apps deportivas de SuuntoPlus durante la sesión
  • Recuerda las apps deportivas de SuuntoPlus tras las sesiones
  • Compatibilidad con los ajustes de la app deportiva SuuntoPlus
  • Nuevo widget del tiempo para previsiones meteorológicas del día
  • Función de linterna en el menú
  • Indicaciones por voz con la app Suunto
  • Los idiomas tailandés y chino tradicional están activados en la edición global
Mejoras:
  • Mejoras en los ajustes de la luz de fondo
2.22.60
Lanzamiento por etapas a partir del 29 de noviembre de 2022
Esta actualización aporta mejoras al rendimiento de GPS en el reloj.
Mejoras:
  • Menos tiempo hasta encontrar la señal GPS
  • Exactitud de posicionamiento mejorada
  • Readquisición más rápida de GPS tras la pérdida de señal
2.22.58
Publicación a partir del 25 de octubre de 2022
Esta actualización aporta algunas funciones nuevas y además corrige algunos errores.
Nuevas funciones:
  • Soporte con conexiones de dispositivos SuuntoPlusTM
  • Potencia de carrera desde la muñeca
  • Modos de deporte Snorkel y Buceo de sirena
