With Suunto Vertical you can have offline maps downloaded on your watch, and leave your phone behind and find your way just by using your watch.
Before you can use offline maps in your watch, you need to set up a wireless network connection in Suunto app and download the selected map area to your watch. You will get a notification on your watch when the map download is complete.
A more detailed instruction on how to set up a wireless network and download offline maps in Suunto app is available here.
Select offline maps before exercise:
If Off is selected in map menu, no map will be shown, only a breadcrumb trail.
Select offline maps without exercising:
Upper button
Lower button
Swipe and tap (if enabled)
If button lock is on, you cannot use the buttons and the swipe and tap functions in the map view.
