Suunto Vertical 2 User Guide
- Adjusting settings
Adjusting settings
You can adjust all watch settings directly in the watch.
To adjust a setting:
- From watch face, long press the middle button.
- Scroll through the settings menu by swiping up/down or by pressing the upper or lower buttons.
- Select a setting by tapping the setting name or pressing the middle button when the setting is highlighted. Go back in the menu by swiping right or selecting Back.
- For settings with a value range, change the value by swiping up/down or by pressing the upper or lower button.
- For settings with just two values, such as on or off, change the value by tapping the setting or by pressing the middle button.
