You can use your watch to navigate in various ways. You can, for example, use it to orient yourself in relation to magnetic north, navigate a route or to a point of interest (POI).
To use the navigation feature:
Select Map.
The map display shows your current location and the surroundings.
If the compass is not calibrated, you are prompted to calibrate the compass when you enter the map.
Press the lower button to open a list of shortcuts. The shortcuts give you quick access to navigation actions such as checking the coordinates of your current location or selecting a route to navigate.
