Suunto Wing 2 User Guide
Voice feedback
If you have a voice feedback capable Suunto watch, you can get voice feedback with valuable information during your exercise. The feedback can help you to keep track of your progress and give you useful indicators, depending on what feedback options you have selected. The headphones must be paired with your watch before using this feature.
This feature is available only on Suunto 9 Peak Pro, Suunto Vertical series, Suunto Race series, and Suunto Ocean series.
To connect your headphones with yout Suunto watch, you need to install the Suunto Wing 2 app from the SuuntoPlus™ Store on the watch.
- Switch the Suunto Wing 2 headphones on.
- From the exercise start screen on your watch, scroll down and select SuuntoPlus™.
- Toggle Suunto Wing 2 app on.
- Wait for the watch to automatically connect with the Suunto Wing 2 headphones.
- Go back and press Start.
When multiple headphones are available for your watch to connect, make sure that you connect the intended devices. When connected to the watch, the headphones play a sound.
If both the headphones and the Suunto app are connected to your watch, voice feedback may be played through the app. To ensure the feedback is heard through the headphones, it’s recommended to close the app in the background.
To activate voice feedback on your watch before an exercise:
- Before starting an exercise, scroll down and select Voice feedback.
- Toggle Voice feedback on.
- Scroll down and select which voice feedback you want activated by turning the toggles on/off.
- Make sure your headphones are on and paired with your watch.
- Go back and start your exercise as you normally do.
Your headphones will now bring you various voice feedback during your exercise, depending on which voice feedback you have activated.
To activate voice feedback on your watch during an exercise:
- Long press the lower button to enter Control panel.
- Scroll down and select Voice feedback.
- Go back and resume your exercise.
